samy-saad
Mar 02, 2022Aspirant
netgearNAS-2120
Hello Am Saturday night the nas was freezing no communication but only pingable after a restart everything comes back. but after a reboot the volume is lost the disks are now red what can i do? ...
samy-saad
Mar 08, 2022Aspirant
Hi,
I did not remove any desk like long before i restart it someone tell me he can't delete file from shared folder
and some file can copy and open and other files no,
just i restart it from webpage, then all volumes not found
model Readynas 2120 v2
frimware 6.9.3
and please check attached file screenshoot
Mar 08, 2022Guru - Experienced User
Ok.
If you need to offload data, then one option is to contact paid Netgear support. They might need you to execute a data recovery contract (which is expensive). https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
Another option is to connect the disks to a Windows PC, and recover data with RAID recovery software. You need a package that supports BTRFS, ReclaiMe is one. https://www.reclaime.com/
Otherwise, you can delete the existing volumes you see on the volume tab, and create a new one. I then would run the disk test from the volume settings wheel. Then download the log zip file, and look for disk errors. You then will need to recreate your shares, and restore the data - but the user accounts, etc would still be there.
No content to show
