darklynx's avatar
Feb 11, 2014
OwnCloud 6.0.0 does not work [solved]
Hi,
I used to have OwnCloud version 5.x installed from ReadyNAS Xtras and it functioned well, although I was disapponted that it is out-dated.
With recent update to firmware 6.1.6 I have noticed that update for OwnCloud 6.0.0 is also available from Poussin, so I updated it.
The result of update was a blank screen if I follow URL: https://<ready nas ip>/owncloud/index.php
I restarted ReadyNAS, I removed OwnCloud, deleted the OwnCloud folder and added OwnCloud app again.
The result is still the same: blank page (with empty HTML source)
I do not have any other applications installed, cause OwnCloud is all I need.
Please help me to undestand or troubleshoot this problem. Maybe I'm missing some dependencies? Installation of PHP from Poussin didn't help me.
I downloaded the log-files from ReadyNAS console, but couldnt find any trace of error or exception related to OwnCloud and why do i see just a blank page.
Thank you in advance!
Lynx
1 Reply
  • I found the reason of my problem. It is related to this issue: https://github.com/owncloud/core/issues/6351
    Unfortunately the only way to solve it at the moment was to get SSH root access to ReadyNAS.
    I modified /etc/php5/conf.d/20-xcache.ini file, the line related to variable cache:
    xcache.var_size = 32M
    Restarted Apache service:
    /etc/init.d/apache2 restart
    And then I was able to continue with OwnCloud 6.0.0 setup.
    Hope this hint will help others who may enconter the same problem.
ProSupport for Business
