WhoCares_
Jul 17, 2012Mentor
OwnCloud 8.0.4
ownCloud[/sizde]
Description
ownCloud> is a flexible, open source file sync and share solution. Whether using a mobile device, a workstation, or a web client, ownCloud prov...
agoodside
Aug 14, 2016Aspirant
Ok. I have gone to rnxtras and purchased the latest update. I won;t install neither will the previous v6? Any help appreciated otherwise sorely disappointed.
mdgm-ntgr
Aug 14, 2016NETGEAR Employee Retired
For the RN104 you need apps for ReadyNAS OS6 (ARM). The OwnCloud app is the one deb for both platforms.
Which firmware are you running? Do you have any other apps installed? Have you tried reaching out to RNXtras/WhoCares? for assistance?
- agoodsideAug 14, 2016Aspirant
Hi mdgm,
thanks for the reply. It's a Radynas 104 OS 6.51 (arm).
No other apps. I went onto the RNxtras website but there is no conatct or support option.....
- mdgm-ntgrAug 14, 2016NETGEAR Employee Retired
You could try the Slack page: https://rnxtras.com/forums
Or perhaps PM WhoCares_ (this is the main developer for the RNXtras site and he posted earlier in this thread).- agoodsideAug 14, 2016Aspirant
The forums are closed....
I PM'd WhoCares_; let's see what he says.
Is there an easy way to at least restore owncloud v6 = default? Even that won't install anymore....
