WhoCares_
Jul 17, 2012Mentor
OwnCloud 8.0.4
ownCloud[/sizde]
Description
ownCloud> is a flexible, open source file sync and share solution. Whether using a mobile device, a workstation, or a web client, ownCloud prov...
dschwartzer
Aug 15, 2016Luminary
I am fairly new to ReadyNASand am running an RN202 with OS 6.5.1. I have seen the OwnCloud app in the Netgear app store but admittedly am confused why I would need this. Isn't one of the reasons to have a ReadyNAS is to have your own cloud services? I did look at the OwnCloud site and there appears to be a lot of apps available but on a basic level, could you explain why someone would use OwnCloud vs. just the readyNAS if all they want is remote access to their files?
Thanks,
David
