WhoCares_
Jul 17, 2012Mentor
OwnCloud 8.0.4
ownCloud[/sizde]
Description
ownCloud> is a flexible, open source file sync and share solution. Whether using a mobile device, a workstation, or a web client, ownCloud prov...
dschwartzer
Aug 15, 2016Luminary
I am fairly new to ReadyNASand am running an RN202 with OS 6.5.1. I have seen the OwnCloud app in the Netgear app store but admittedly am confused why I would need this. Isn't one of the reasons to have a ReadyNAS is to have your own cloud services? I did look at the OwnCloud site and there appears to be a lot of apps available but on a basic level, could you explain why someone would use OwnCloud vs. just the readyNAS if all they want is remote access to their files?
Thanks,
David
Aug 15, 2016Guru - Experienced User
If all you want is remote access, then you have basically two alternatives
-use port forwarding for ftps (or https) combined with ddns
-use OpenVPN combined with ddns
You can also use a variety of other tools that have additional features - generally sync and controlled sharing
-ReadyCloud
-OwnCloud
-Bittorent Sync
-Amazon Cloud sync
-plex (limited to media)
You can learn more about the OwnCloud features here: https://owncloud.org/features/
Personally I use OpenVPN for general remote access - that runs in my R8500 router. Clients are installed on my mobile devices and laptop.
I've been playing with Bittorrent sync for some folders - one benefit is that it will transfer files in the background. I'm not running it on my NAS though - I run it on a PC (with the NAS mapped to a drive letter).
I also use plex, and allow family members access to my media.
