WhoCares_
Jul 17, 2012Mentor
OwnCloud 8.0.4
ownCloud[/sizde]
Description
ownCloud> is a flexible, open source file sync and share solution. Whether using a mobile device, a workstation, or a web client, ownCloud prov...
osilvab
Dec 31, 2016Aspirant
here it is:
Welcome to ReadyNASOS 6.6.0 Last login: Fri Dec 30 16:28:04 2016 from 192.168.0.110 root@NASPON:~# df -kh Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 1010M 2.8G 27% / tmpfs 249M 4.0K 249M 1% /dev/shm tmpfs 249M 476K 248M 1% /run tmpfs 125M 0 125M 0% /run/lock tmpfs 249M 0 249M 0% /sys/fs/cgroup /dev/md127 2.8T 971G 1.8T 35% /data /dev/md127 2.8T 971G 1.8T 35% /home /dev/md127 2.8T 971G 1.8T 35% /apps
it would be strange for me that there is no space. i do not have installed any app.
FramerV
Jan 01, 2017NETGEAR Employee Retired
Hi osilvab,
Does seem that you have space on your OS partition. Let's wait for a feedback from WhoCares_.
