WhoCares_
Jul 17, 2012Mentor
OwnCloud 8.0.4
ownCloud[/sizde]
Description
ownCloud> is a flexible, open source file sync and share solution. Whether using a mobile device, a workstation, or a web client, ownCloud prov...
osilvab
Jan 03, 2017Aspirant
whocares assisted me. the problem seem to be related to the broswer i was using (edge) as soon as I try another one it worked perfectly.
WhoCares_
Jan 03, 2017Mentor
Note to moderators: As it seems Edge is sending not just the filename but the complete path instead when uploading a file. So instead of receiving for example "owncloud_9.1.3-rnx1_all.deb" the ReadyNAS will get a filename like "C:\Users\username\Downloads\owncloud_9.1.3-rnx1_all.deb". This will make the install procedure fail when trying to actually install the package using dpkg. Solution for now is to recommend using a different browser to the users, a better solution would be to find a workaround that can be implemented server side.
-Stefan
