WhoCares_
Jul 17, 2012Mentor
OwnCloud 8.0.4
ownCloud[/sizde]
Description
ownCloud> is a flexible, open source file sync and share solution. Whether using a mobile device, a workstation, or a web client, ownCloud prov...
Forage
Sep 29, 2015Apprentice
The following curl issue occurs when trying to get an add-on list: https://github.com/owncloud/core/issues/19127
Does that happen to you as well or did you manage to fix it somehow?
