Sa9aX11
Aug 17, 2016Guide
OwnCloud 9.0.2 (ReadyNAS 102)
Hi I'm having problem installing OwnCloud 9.0.2 (owncloud_9.0.2-rnx1_all.deb) also tried v9.0.0, I just purchased from RNXtras.com but the installation failed. I used "upload" button on my Read...
- Feb 14, 2017
Hi
Sorry I was a bit late to answer your question, I found something under "Community Addons" Forum that helped me, I was reading thru and found a link:- https://www.dropbox.com/sh/ie9pwk1wut72ias/p6_X2QeOIC
Here I found the latest version of OwnCloud that worked for me, there are other latest Apps and new ones , if you install the new ones they show up in the "Installed Apps" section but if you uninstall them they don't show up in "Available Apps" section so you need to keep the app files for later use if you need them.
Sal.
JennC
Aug 18, 2016NETGEAR Employee Retired
Hello Sa9aX11,
The current version available on Available Apps list is 6.0.0. The developer needs to submit updated version first.
If you are trying the app from RNXtras.com, it may be possible that it is isn't compatible with the current FW version you have. Are you on the latest FW version?
- Sa9aX11Aug 18, 2016Guide
JennC wrote:Hello Sa9aX11,
Yes 6.5.1, the old version 6.0.0 is not on Apps List, I have tried to install the old version but that failed too.
Will re-installing the firmware fix this?
- BrianL2Aug 18, 2016NETGEAR Employee Retired
Hi Sa9aX11,
Does your ReadyNAS connect to the internet properly? Let's also ask super_poussin if the latest add-on version has a with the latest official Firmware.
Kind regards,
BrianL
NETGEAR Community Team- Sa9aX11Aug 19, 2016Guide
Yes Internet works.
I remember I was using v6 but I removed it, because there was a new version out so I remove the old version, I remove the whole directory for a mistake (\\ReadyNAS\data\.apps\.freeapps\owncloud) and now its not showing up in App lists if I wan't to install it again.
