Sa9aX11
Aug 17, 2016Guide
OwnCloud 9.0.2 (ReadyNAS 102)
Hi I'm having problem installing OwnCloud 9.0.2 (owncloud_9.0.2-rnx1_all.deb) also tried v9.0.0, I just purchased from RNXtras.com but the installation failed. I used "upload" button on my Read...
- Feb 14, 2017
Hi
Sorry I was a bit late to answer your question, I found something under "Community Addons" Forum that helped me, I was reading thru and found a link:- https://www.dropbox.com/sh/ie9pwk1wut72ias/p6_X2QeOIC
Here I found the latest version of OwnCloud that worked for me, there are other latest Apps and new ones , if you install the new ones they show up in the "Installed Apps" section but if you uninstall them they don't show up in "Available Apps" section so you need to keep the app files for later use if you need them.
Sal.
Sa9aX11
Aug 21, 2016Guide
BrianL2 wrote:Hi Sa9aX11,
Does your ReadyNAS connect to the internet properly? Let's also ask super_poussin if the latest add-on version has a with the latest official Firmware.
Kind regards,
BrianL
NETGEAR Community Team
I sent a message to super_poussin 2 days ago but not getting any replies from the person.
Sal.
Sa9aX11
Feb 14, 2017Guide
Hi
Sal.
