mike83cz
Aug 17, 2016Follower
OwnCloud 9.1 WebDAV, Permissions and HTTP Issue
Hey everyone, I installed lastest OwnCloud 9.1 on my Ready NAS (RN214,FW6.5.1). Not the Addon, but normally on the webserver using MySQL. So only apps installed are PHP, MySQL and phpMyAdmin. Por...
JennC
Aug 17, 2016NETGEAR Employee Retired
Hello mike83cz,
Welcome to the community!
Where did you get the add-on? Even if it is from the available apps, once installed, you need to check the configuration with the developer.
CharD
Aug 18, 2016Aspirant
First of all. Please use Nextcloud instead of ownCloud. It is more secure and has more features.
1. You probalby should DISABLE Webdav in your settings. Because outerwise it collides with the WebDAV server that is part of Nextcloud
2. This measn that your apache doesn't allow to override some settings with a .htaccess file. You should check this documentation how to configure your apache: https://docs.nextcloud.com/server/9/admin_manual/installation/source_installation.html
3. You need an SSL cert. I recommend that you look into https://letsencrypt.org to get a cert and configure your apache.
I hope this helps :-)
- StephenBAug 18, 2016Guru - Experienced User
No real opinion on that, though the formation of NextCloud has undoubtedly done some financial damage to OwnCloud. A bit of a mess I think. https://owncloud.org/blog/owncloud-statement-concerning-the-formation-of-nextcloud-by-frank-karlitschek/
- ArchPrimeJan 13, 2017Guide
Hi - I am struggling to find a noob friendly way (or any way) to install Nextcloud on ReadyNAS.
How do I do it?
Where would I find a supported NextCloud.deb file that I can upload using the official ReadyNAS apps manual install method?
- FramerVJan 14, 2017NETGEAR Employee Retired
Hi ArchPrime,
I apologize about this but I do not have articles for the NextCloud. I think CharD placed a link for the setup. You could probably try check the NextCloud forum also.
