Sandshark's avatar
Sandshark
Sensei
Feb 12, 2017
OwnCloud external storage -- problem and work-around
Running OS 6.1.1 on ReadyNAS Pro2 with OwnCloud app owncloud_9.1.3-rnx2_all.deb from RNXtras.
I decided I wanted to mount a directory on another NAS as an external source,  I enabled the External Sources module in OwnCloud and set everything up for SMB access to the other NAS.  Got a "Green Light" on the settings and thought all was OK, but it failed to show any files when I accessed the directory.  There was a horribly long error message in the log that basically came down to "Can't access external share".  Googling told me that I might need php5-libsmbclient_0.7.0-10.2_amd64.deb, so i installed that.  Still no-go.  So I tried FTP.  Didn't even get the green light on that.  Yes the user name I was using has both SMB and FTP access, both verified outside of OwnCloud.
I remember seeing where the ReadyNAS does not support Active Mode FTP, and figured that could be the problem.  But I can't find a solution to use SMB or a good reason why it won't work.  The php5-libsmbclient (or it's equivalent for other distros) seemed to be the solution for everyone with non-NAS installations.  It may have something to do with the somewhat non-traditional install that keeps OwnCloud from filling the system partition.
But, I did find a work-around.  I created a symbolic link in /mnt and added an NFS mount of the link in fstab so it mounts at boot.  Then I created the external storage link in OwnCloud using "Local" mode to that symlink.  Voila, it worked!  I just wanted it to be read-only, so used the ro option in the NFS mount and admin credentials in OwnCloud, so I don't know what permissions might be needed if you want it read/write.  One time I rebooted and the directory was empty.  I suspect that the other NAS was in spin-down mode at the time and something timed out.  It would be nice if it all worked as it should directly from the OwnCloud GUI, but this is a work-around others can try if they need it until somebody figures out how to fix the problem with external SMB storage.
  • Until I do some more investigating, label this "Use with extreme caution".  All of the files in the directory I shared suddently had their ownership changed (to 65534, whihc I believe to be unassigned), and I could not access them normally via SMB.  I'm assuming for now that this was the cause.
    I changed the ownership to guest:guest and all is working via SMB to the host NAS and OwnCloud from the NAS where I mounted it, but that could change again (maybe on re-boot).  I also changed the ownership of the link target to guest:guest and maybe that will fix it.
  • FramerV's avatar
    FramerV
    NETGEAR Employee Retired
    Hi Sandshark,
    Thank you for sharing your resolution and/or workaround. We appreciate your contribution to the community.
    Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
ProSupport for Business
