viperhansa
Jan 01, 2017Virtuoso
Owncloud for ReadyNas PRO OS6.6 (legacy)
Hi all. Can anyone do an install package for OwnCloud? Or is there one for download somewhere? WhoCares have removed all his versions. Regards // Hans
osilvab
Jan 08, 2017Aspirant
no other services.
- viperhansaJan 16, 2017Virtuoso
Hi JennC
i did, he have an updated version that works fine for now.
Regards
Hans
- JennCJan 17, 2017NETGEAR Employee Retired
Hello viperhansa,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
