The_Garden_Snak
Feb 15, 2017Aspirant
Owncloud security.
Hello. I'm really a novice when it comes to internet security. So i have some questions. I have installed OwnCloud on my readynas ultra 4. I would like to know if im accessing it securely. When...
Sandshark
Feb 16, 2017Sensei
It means that a hacker could potentially intercept your data transfer and decode it, including the user name/password for access. But that only gets him into OwnCloud, not the whole NAS unless you are sharing it via Owncloud.
But do you even have anything on your OwnCloud that would do you harm if a hacker got ahold of it? And what's the chance that a hacker will even care to try and access your OwnCoud?
- The_Garden_SnakFeb 16, 2017Aspirant
Im only sharing OwnCloud. Im in the process of setting this up, so i have not anything on OwnCloud yet. But is there possible to uppgrade to SHA2 on the readynas to make the encryption more secure?
- StephenBFeb 17, 2017Guru - Experienced User
FWIW, the most recent estimate I've seen on the cloud computing cost of compromising an SHA-1 certificate is about $100,000.
That's certainly affordable if you are going after a commercial domain name. But I think it's enough to make it unlikely that attackers will target self-signed certs.
That said, Netgear should be generating SHA-2. SHA-1 deprecation has been in the works since 2014.
