The_Garden_Snak
Feb 15, 2017Aspirant
Owncloud security.
Hello. I'm really a novice when it comes to internet security. So i have some questions. I have installed OwnCloud on my readynas ultra 4. I would like to know if im accessing it securely. When...
The_Garden_Snak
Feb 18, 2017Aspirant
When you say should, does thay mean they dont generate sha2? Or can i upgrade my readynas in a way?
Feb 18, 2017Guru - Experienced User
To be more precise, they should stop generating SHA-1.
There is no update available now that will do that. But as I tried to say before, the risk is minimal right now (unless an attacker is prepared to spend $100k to forge the certificate, and launch some form of man-in-the middle attack against you).
