super_poussin's avatar
Oct 01, 2008
PHPLogCon - Loganalyzer
PHPLogcon
  • Description: see your syslog message.
    phpLogCon is a web interface to syslog and other network event data. It provides easy browsing and some basic analysis of realtime network events. Depending on the applications feeding the database, it can process syslog messages, Windows event log entries and even SNMP trap data - just to name a few.
    phpLogCon is part of Adiscon's MonitorWare line of monitoring applications. It runs both under Windows and Unix/Linux. The database can be populated by MonitorWare Agent, WinSyslog or EventReporter on the Windows side and by rsyslog on the Unix/Linux side. phpLogCon itself is free, GPLed software (as are some other memebers of the product line
  • Requirements: RAIDiator 4.2.13+ and PHP Addon for the PRo
  • Platform: PRO/NVX
  • Current Version: 1.5
    PHPLogCon (08/28/10)
    • PHPlogcon is now called Log analyzer
    • Based on 3.01 (3.0 beta)
    • correct a bug on remote syslog
    • syslogd will accept connection from other system
    • add users log
    • add frontview error log (choose web log format)
    • Installation Notes: you need to install PHP addon first if not already done
      user is admin with your frontview password
    • Screenshots:
    • Old Versions:
      Removed
    • Credits and Sources:
      Log analyzer web site
1 Reply
ProSupport for Business
