will3b
May 07, 2020Aspirant
problem building kernel modules for 6.10.3
Hi all,
I am facing a problem as I'm trying to build wireguard as a kernel module for my ReadyNAS 102, on a 6.10.3 firmware.
I searched the forum a bit and found a related issue here : https://community.netgear.com/t5/New-ReadyNAS-Users-General/6-9-5-GPL-not-posted/m-p/1711456) but unfortunately the solution posted by WhoCares_ does not work for me and I am not able to load the compiled module.
I followed the steps listed in the thread:
- got the firmware sources (ReadyNASOS_V6.10.3_WW_src.zip)
- installed the linux-image-extra package on my NAS, loaded the configs module and dumped the running config from /proc/config.gz
- compiled the kernel using this .config
- compiled the wireguard module from git sources
Everything compiles just fine, but when I try to insmod the wireguard.ko module against the running Netgear stock kernel (4.4.190.armada.1), I get the following error:
insmod: ERROR: could not insert module wireguard.ko: Invalid module format
dmesg shows the following error :
[3668461.294231] wireguard: disagrees about version of symbol module_layout
I tried building the module on both the dev VM and the NAS itself, unfortunately with the same result...
Has anyone figured out how to successfully compile and load a custom kernel module on 6.10.x firmwares ?
- WhoCares_Mentor
The problem is that since GPL 6.9.4 NTGR "forgot" to ship their Alpine patches with the kernel sources. This essentially means that all the stuff that makes the kernel run on RN1xx and RN2xx boards is missing. What I'm currently trying is to build a working patch by adapting the diff from the NTGR supplied kernel sources 4.4.116 (the last version that contains their patches) to kernel 4.4.190 (the one shipping with 6.10.3.
-Stefan
- will3bAspirant
Thanks for your answer.
My RN102 is based on a Marvel armada 370 CPU, so I thought I didn't need the alpine kernel source tree. A few alpine kernel modules indeed lie on the file system of my NAS (in /lib/modules/4.4.190.alpine.1/) but they seem unused and cannot be loaded on my system :
# insmod /lib/modules/4.4.190.alpine.1/kernel/kernel/configs.ko insmod: ERROR: could not insert module /lib/modules/4.4.190.alpine.1/kernel/kernel/configs.ko: Invalid module format
Are you sure these sources are needed to build a working module for RN102? Or do you mean we are missing a few patches originally coming from the alpine source tree that were backported to the arm kernel for the official NTGR firmware release but not present in the provided sources?
- WhoCares_Mentor
Sorry, I was a bit unclear there. The patches from NTGR also include stuff targeted at Marvell 370 and 380 chipsets. Looks like they changed their build pipeline in such a way that only the x86 code (which I suspect is the main focus anyway) comes out correct whereas ARM and Alpine are broken.
-Stefan
