will3b
May 07, 2020Aspirant
problem building kernel modules for 6.10.3
Hi all, I am facing a problem as I'm trying to build wireguard as a kernel module for my ReadyNAS 102, on a 6.10.3 firmware. I searched the forum a bit and found a related issue here : https://c...
WhoCares_
May 08, 2020Mentor
Sorry, I was a bit unclear there. The patches from NTGR also include stuff targeted at Marvell 370 and 380 chipsets. Looks like they changed their build pipeline in such a way that only the x86 code (which I suspect is the main focus anyway) comes out correct whereas ARM and Alpine are broken.
-Stefan
WhoCares_
May 08, 2020Mentor
Here's a diff someone else did on the 4.4.111 kernel sources -> https://gist.github.com/donbowman/2630241daadd43122163a7fae57e10b3
From a brief glance I'd say, yes, you're likely to need them to build a working kernel for the RN1xx series too.
-Stefan
