it-guru
Sep 11, 2015Aspirant
Problems while creating the .config for 3.12.43 Kernel in ReadyNASOS 6.3.5 (for comp. USB Modules)
I am running 6.3.5 on my ReadyNAS Ultra 2 Plus and all works fine. My Problem ist, i need to add the OneWire USB Modules to my system for a Home-Automation solution. This was my approach to get m...
mdgm-ntgr
Sep 22, 2015NETGEAR Employee Retired
6.3.5 was released for the 200 series (alpine arm).
We have a newer kernel again in 6.4.0 beta.
it-guru
Sep 24, 2015Aspirant
OK, now i have installed ReadyNASOS-6.4.0-T147-x86_64.img an it seems to work good.
But now i could not find the sources for this image.
At http://kb.netgear.com/app/answers/detail/a_id/2649/~/gpl-open-source-code-for-programmers there is no source package for the 6.4.0-T147 image.
Where can i found the source package, in which the source for the kernel 4.1.7 is included? (and the the needed .config file for the kernel to compile modules)
- Mar 10, 2018Retired_Member
