gbeddow
Sep 23, 2016Luminary
Antivirus false positives
Hi, ReadyNAS Antivirus is flagging a couple of files in the current version of WordPress, zxcvbn-async.min.js and wp-fullscreen-stub.min.js, but there doesn't appear to be anything wrong with the...
gbeddow
Sep 27, 2016Luminary
Hi JennC,
It's not clear to me what's happening for you. Can you describe the steps you're taking in more detail?
Thanks,
Greg
B_L
Sep 28, 2016NETGEAR Expert
Thank you for reporting this issue. It was fixed in the AV definiation update. Please make sure your AV definition file is up-to-date. The version should be 201609281626 or late.
You can install Anti-Vius Plus app, click the "Cehck Update" button to update the definition file.
There is a known bug that the "Definition File" is empty in Anti-Virus Plus app 2.0.4. It will be fixed in the next release 2.0.5.
