NTGR-OPS
Jun 23, 2017Tutor
couchpotato fails to start
Well, I know this might seem like an old topic, but I cannot find an answer and after several hours trying everthing I can think of on my own, have decided to reach out to the experts. I had Couc...
- Jun 24, 2017
Found new version on GIT. Seems to have fixed it.
JennC
Jun 23, 2017NETGEAR Employee Retired
Hello NTGR-OPS,
What's the model number of your NAS and its firmware version?
If it is ReadyNAS OS6 firmware, can you post what you get from install_debpkg.log?
NTGR-OPS
Jun 24, 2017Tutor
Log sent. Thanks for your help.
RN31600
6.7.4
Someone suggested this?
Remove this from /var/lib/ddpkg/status, and reinstall. i'm concerned about the purge ok installed status.
Package: couchpotato
Status: purge ok installed
Priority: extra
Section: contrib
Installed-Size: 9980
Maintainer: Mhynlo <[email protected]>
Architecture: all
Version: 3.0.1-1
Depends: readynasos (>= 6.1.0), php5-sqlite, python, git
Description: CouchPotato
Automatic Movie Downloading via NZBs & Torrents.
Homepage: https://couchpota.to/
also, reinstalling fails.
root@ReadyNAS:~# apt-get install --reinstall couchpotato
Reading package lists... Done
Building dependency tree
Reading state information... Done
Reinstallation of couchpotato is not possible, it cannot be downloaded.
0 upgraded, 0 newly installed, 0 to remove and 79 not upgraded.
- NTGR-OPSJun 24, 2017Tutor
