Blueray3
May 29, 2017Guide
Entire Dropbox
I would like to sync my entire Dropbox (several folders) with a share on my ReadyNAS OS6.7.4. I may be missing something, but it looked as tho I could only sync one foler of my Dropbox to a single s...
- Jul 13, 2017
Here the session mean the sync pair between local path and remote path. You can add multiple sync pairs (sessions) as long as you do not sync your entire Dropbox drive to NAS, otherwise you can have only one sync pair (session).
Blueray3
Jun 06, 2017Guide
Thanks for the info. When I sync from the root directory, I see the message: syncing the root folder will sync the entire public cloud, preventing you from adding new sessions.
Am not sure what this means. Does "public cloud" mean that syncing changes permissions on either the Dropbox or the ReadyNAS? And what is "adding new sessions"? -Does this mean that I can not add new folders to either the Dropbox or to the ReadyNAS Dropbox share (assuming bidirectional syncing) or does it mean something else? -Thanks
B_L
Jul 13, 2017NETGEAR Expert
