Geeks_Alex
Feb 29, 2016Tutor
Transmission 2.90 is out ^^
Hello, Juste to say the last build of transmission is out. Hope the will have an update for readyNas ^^ Thanks
JennC
Mar 01, 2016NETGEAR Employee Retired
Hello Geeks_Alex,
Which ReadyNAS series are you referring to? The version that OS6 NAS is using is 2.82.
For cases like these, you may contact the developer. WhoCares_ I believe is the one active here and has Transmission apps.
Welcome to the community!
super_poussin
Mar 01, 2016Virtuoso
I'm not retired just less active in particular on trnasmission which was not updated by transmission team since a long time
but version for R6 and R4 (X86) is out
regards
- PKing83Mar 02, 2016Aspirant
Merci for the R4 (X86) super_poussin!
- viliuspMar 04, 2016Aspirant
Hey,
will this work with the new 6.4.2 firmware? I updated NAS to the newest firmware and Transmission stops working correctly. Well, it responds, but all the transfers are staying still.
- OCYinzRJun 12, 2016Aspirant
Can somebody pease let me know where to download v2.90 for R4 x86? I can only find the older v2.84.
Kind Regards,
OCYinzR
