xupaaki
Oct 14, 2015Tutor
Transmission 3.00.8 Permission denied
Hi, I cant find a way to make transmission working on my rn102 with 6.2.5 or 6.4 firmware... previous version of transmission used to work great, but since I factory reseted the NAS first installing...
JennC
Oct 15, 2015NETGEAR Employee Retired
Hello xupaaki,
Can you try adding 8.8.8.8 as DNS server?
Go to admin page of NAS, then Network, click settings for the Ethernet it is using then DNS.
Once done, check the Transmission again.
xupaaki
Oct 15, 2015Tutor
tried that...but didn´t work...anyway I found a solution...
I did once again a factory reset, but just with one hdd inside...
I had to use raidar after that because I was unable to acess the GUI.... Raidar was able to acess the NAS but told I had to format the HDD...so I did...reinstalled all the apps and the second HDD....magicaly now everything is working....3 factory reset later!!!
