osilvab
Aug 29, 2017Aspirant
Uprading to Owncloud 10
Hi, I have the Netgear ReadyNAS 102 with firmware 6.8. I had previosly installed owncloud from RNXtra (owncloud_9.1.3-rnx1_all.deb). It has some updates pending, I tired to run them and some err...
- Sep 05, 2017
Thanks for the logs. The problems you're having seem to come from the package "owncloud-deps-php5" - which isn't part of any owncloud or nextcloud app I made. I have no idea where this comes from or what app this belongs to. Some googling lets me believe that this is from an Ubuntu package and maybe is a left-over from an attempt to manually install from other packages?
Anyway, this particular package seems to break any install since the system tries (and fails) to install it on every install/update. So my suggestion would be to manually remove the package using "dpkg -r owncloud-deps-php5" and then try reinstalling either the OwnCloud or the NextCloud
app (or both if you like).
-Stefan
osilvab
Aug 31, 2017Aspirant
Hi,
i was trying to upgrade from owncloud_9.1.3-rnx1_all.deb to 10.0.2
Readynas has OS 6.8.0
I bought the mysql as in your page said it was required for that version of owncloud. Same for the nextcloud. anyway I couldnt install it.
I don't have more apps istalled. I also think it comes from a failure during the instalation. but it also happenswhen trying to install Nextcloud, that is a "clean" instalation.
I checked the logs in the Netgear admin I found something apprently from the first time I tried the instalations:
Wed Aug 30 2017 7:55:40 System: Cannot install application nextcloud. Wed Aug 30 2017 7:53:35 Share: Share Nextcloud was added. Wed Aug 30 2017 7:44:55 System: Cannot install application owncloud. Wed Aug 30 2017 7:40:35 System: Found app [owncloud] with bad configuration. Disabling its configuration page. Wed Aug 30 2017 7:39:13 System: Cannot install application mysqldb.
In the system journal here are no records on those days, the file starts like this:
-- Logs begin at Sun 2017-08-06 01:09:02 CEST, end at Thu 2017-08-31 14:20:22 CEST. -- Aug 30 11:50:47 NASPlanetON apache_access[4432]: 129.16.138.140 "GET /owncloud/status.php HTTP/1.1" 404 Aug 30 11:50:47 NASPlanetON apache2[5399]: [error] [client 129.16.138.140] File does not exist: /apps/owncloud Aug 30 11:50:47 NASPlanetON apache_access[4432]: 129.16.138.140 "GET /owncloud/owncloud/status.php HTTP/1.1" 404 Aug 30 11:51:19 NASPlanetON apache2[4436]: [error] [client 129.16.138.140] File does not exist: /apps/owncloud
the error of the not existing folder /apps/owncloud is repeating all the time. In fact the folder is not there anymore.
I found other logs when tring to install owncloud:
Aug 31 13:07:52 NASPlanetON readynasd[2534]: Errors were encountered while processing: Aug 31 13:07:52 NASPlanetON readynasd[2534]: owncloud-deps-php5 Aug 31 13:07:54 NASPlanetON readynasd[2534]: E: Sub-process /usr/bin/dpkg returned an error code (1) Aug 31 13:07:58 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:07:59 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:08:00 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:08:00 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:08:01 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:08:01 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:08:02 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:08:02 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:08:03 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:08:03 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:08:04 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:08:04 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:08:05 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:08:05 NASPlanetON fv-app-install[20248]: Downloading [owncloud](0%) Retrieving file 1 of 1 Aug 31 13:08:05 NASPlanetON fv-app-install[20248]: Downloading [owncloud](50%) Retrieving file 1 of 1 Aug 31 13:08:06 NASPlanetON fv-app-install[20248]: Installing [owncloud](50%) Running dpkg Aug 31 13:08:07 NASPlanetON fv-app-install[20248]: Installing [owncloud](50%) Installing owncloud Aug 31 13:08:07 NASPlanetON fv-app-install[20248]: Installing [owncloud](56%) Preparing owncloud Aug 31 13:08:11 NASPlanetON apache2[20415]: [error] [client 192.168.0.112] script '/apps/owncloud/web/status.php' not found or unable to stat
And ths is for nextcloud:
Aug 31 13:43:22 NASPlanetON fv-app-install[22529]: [/tmp/nextcloud_12.0.1-rnx1_all.deb](0%) prepare Aug 31 13:43:45 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:45 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:46 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:46 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:47 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:47 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:48 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:48 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:49 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:49 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:50 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:50 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:51 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:52 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:52 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:53 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:53 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](0%) Retrieving file 1 of 1 Aug 31 13:43:53 NASPlanetON fv-app-install[22529]: Downloading [nextcloud](50%) Retrieving file 1 of 1 Aug 31 13:43:54 NASPlanetON fv-app-install[22529]: Installing [nextcloud](50%) Running dpkg Aug 31 13:43:55 NASPlanetON fv-app-install[22529]: Installing [nextcloud](50%) Installing nextcloud Aug 31 13:43:55 NASPlanetON fv-app-install[22529]: Installing [nextcloud](56%) Preparing nextcloud Aug 31 13:45:06 NASPlanetON fv-app-install[22529]: Installing [nextcloud](61%) Unpacking nextcloud Aug 31 13:45:06 NASPlanetON fv-app-install[22529]: Installing [nextcloud](67%) Preparing to configure nextcloud Aug 31 13:45:07 NASPlanetON fv-app-install[22529]: Installing [nextcloud](67%) Running dpkg Aug 31 13:45:07 NASPlanetON fv-app-install[22529]: Installing [nextcloud](67%) Configuring owncloud-deps-php5 Aug 31 13:45:20 NASPlanetON fv-app-install[22529]: Installing [nextcloud](67%) Configuring nextcloud Aug 31 13:45:20 NASPlanetON fv-app-install[22529]: Installing [nextcloud](72%) Configuring nextcloud Aug 31 13:45:23 NASPlanetON fv-app-install[22529]: Installing [nextcloud](78%) Installed nextcloud ug 31 13:45:23 NASPlanetON smbd[23297]: STATUS=daemon 'smbd' finished starting up and ready to serve connections Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: fv-app-install (/tmp/nextcloud_12.0.1-rnx1_all.deb): error code [100]: Reading package lists... Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: Building dependency tree... Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: Reading state information... Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: The following NEW packages will be installed: Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: nextcloud Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: 0 upgraded, 1 newly installed, 0 to remove and 31 not upgraded. Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: 1 not fully installed or removed. Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: Need to get 0 B/35.6 MB of archives. Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: After this operation, 140 MB of additional disk space will be used. Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: Get:1 /tmp/nextcloud_12.0.1-rnx1_all.deb nextcloud all 12.0.1-rnx1 [35.6 MB] Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: debconf: delaying package configuration, since apt-utils is not installed Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: Selecting previously unselected package nextcloud. Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 5% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 10% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 15% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 20% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 25% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 30% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 35% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 40% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 45% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 50% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 55% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 60% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 65% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 70% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 75% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 80% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 85% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 90% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 95% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 100% Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: (Reading database ... 33759 files and directories currently installed.) Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: Preparing to unpack .../nextcloud_12.0.1-rnx1_all.deb ... Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: Unpacking nextcloud (12.0.1-rnx1) ... Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: Setting up owncloud-deps-php5 (9.1.6-1.1) ... Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: apache2_invoke rewrite: already enabled Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: dpkg: error processing package owncloud-deps-php5 (--configure): Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: subprocess installed post-installation script returned error exit status 1 Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: Setting up nextcloud (12.0.1-rnx1) ... Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: grep: /apps/nextcloud/web/config/config.php: No such file or directory Aug 31 13:45:25 NASPlanetON fv-app-install[22529]: sed: can't read /apps/nextcloud/web/config/config.php: No such file or directory
I hope it gives some clue.
Thank you!
WhoCares_
Sep 05, 2017Mentor
-Stefan
- osilvabSep 05, 2017Aspirant
Thanks that solved the issue.
I was having problems with other things after the update of the OS and I run updates from the console. I wasnt aware at the moment tat it would try to udate the owncloud also.
I will give a look to NextCloud also.
