forestpct
Sep 17, 2015Guide
ReadNas Duo V1 - LMS and ReadyDNLA queries
Have a ReadyNas Duo V1 with RAIDiator V4.1.14 firmaware installed. Have Logitech Media Server Add-On at 7.7.2 installed and ReadyDLNA is shown as V1.1.4. Both components work fine with Squeezebox D...
- Sep 17, 2015
If it is for the Duo v1 (Sparc) then yes it should work.
1.1.4 is the latest version for your Duo v1: https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyDLNA-Update-Addons-Updated-2014-11-13/td-p/653608
mdgm-ntgr
Sep 17, 2015NETGEAR Employee Retired
