Redwolf
Apr 27, 2017Aspirant
ReadyNAS 104 running 6.6.1 amazon deleting files
I just read a post here which claims this problem was discovered and then solved in 6.6.1. It is not. I have been syncing to amazon for a few months, with a fear that this would happen, and ...
Apr 27, 2017Guru - Experienced User
Of course it's always bad when data is lost. I hope you can manage to get the files back.
I am not seeing any cloud fixes in the 6.6.1 release notes. I suspect the fix made in your linked post ended up in 6.7.0.
While you are waiting for Netgear to respond, I suggest rebooting your NAS in read-only mode. That will prevent the deleted files from being overwritten (and not recoverable).
