Francey532
Jan 20, 2016Aspirant
Readynas 204
Hi when I go to my admin page I click on apps and install one, when I launch the app if says authentication required and asks me to log in, when I do nothing happens like my username and password are ...
Francey532
It's transmission and it's happened on a few of the apps. I'm running the latest firmware not sure which version, is there a way to find this out
mdgm-ntgr
Jan 20, 2016NETGEAR Employee Retired
The firmware version e.g. 6.4.1 will show on the home page of the web admin interface.
Some apps require authentication which may be separate to what is used for the web admin interface.
You could try the username admin with passwords such as "admin" (no quotes), "password" (no quotes) etc.
Looking up on the web for default credentials for e.g. Transmission may also be helpful.
- StephenBJan 20, 2016Guru - Experienced User
I don't use transmission, but according to the wiki ( https://help.ubuntu.com/community/TransmissionHowTo#Username_and_Password ) the default username and password are both "transmission".
- JennCJan 23, 2016NETGEAR Employee Retired
Hello Francey532,
Have you tried admin/admin?
See Re: Default login/password for Transmission on OS 6.x where response is from the developer.
