scravatt
Jan 31, 2023Apprentice
Readynas 51600
The ReadyCloud IOS app is broken. It does not work on IOS 16.2 or higher. It logs in, shows my devices and just hangs. I know it worked specifically on IOS 15.7.3. It broke somewhere around IOS 16.2...
Sandshark
Jan 31, 2023Sensei
ReadyCloud is being taken out of service next month, so it is highly unlikely that anything will be done with the app at this point.
In what way are you using ReadyCloud (so alternatives can be suggested)?
- scravattFeb 03, 2023Apprentice
I just use it to access files on my NAS remotely. I use the IOS app to do that when I'm mobile. It works on IOS 16.2 but not on 16.3. Probably a simple fix to get it working.
- StephenBFeb 03, 2023Guru - Experienced User
But unlikely they will touch it, since they are dropping the service anyway.
Are you interested in alternative solutions? There are a couple:
- using a router-hosted VPN (for instance OpenVPN, which is in the Nighthawk and Orbi routers)
- using ZeroTier (which would be run on the RN516)
- using port-forwarding for FTPS or SFTP
- scravattFeb 08, 2023Apprentice
how to i setup for FTPS or SFTP?
- klausnMar 05, 2023Tutor
Hi,
Just I wonder why it stops?
I have seen this topic else on the Netgear platform but can't reply on it..... and it seems it doesn't work anymore for some month.
It was a real pleasure to use it.....such a sadness then we need to switchover to another vendor.
