AFAYK
Jan 15, 2018Aspirant
ReadyNAS not syncing anymore with dropbox. Was originally
This is regarding the ReadyNAS 426. The form wouldn't let me seleect that. I set it up to sunc both ways with Dropbox. Initially the setup was a breeze and ecverything started syncing. Now as ...
Marc_V
Jan 16, 2018NETGEAR Employee Retired
Hi AFAYK
Welcome to the Community!
Are you getting any message? Have you checked the logs?
Can you try syncing one way and see if data will be pushed to Dropbox fine. Recommendation is that Dropbox cap should be equal or higher than the NAS cap.
Regards
- AFAYKJan 16, 2018Aspirant
Thank you Marc.
There doesn't seem to be any messages.
There is no cap on the NAS itself, and the Dropbox ap installed only has three settings.
The cap for the dropbox account is around 5tb and we are at 3tb.
Attached are screen shots of image uploaded (uploadedchicken) uploaded through the web interface, and then a screen shot showing the local files on the NAS without the uploaded file appearing. I do not know how much time should be allowed to pass.
So, syncing is not happening in either direction bewtween the NAS and the dropbox account.
I have set up this same NAS twice to work with Ignight and havent had issues, and I am familiar with them, fyi.
Thanks again.
- AFAYKJan 17, 2018Aspirant
Checking back today on the account and no syncing has happened between the dropbox and the device. Attached is a screen shot showing that the device is indeed listed as a link.
