AFAYK
Jan 15, 2018Aspirant
ReadyNAS not syncing anymore with dropbox. Was originally
This is regarding the ReadyNAS 426. The form wouldn't let me seleect that. I set it up to sunc both ways with Dropbox. Initially the setup was a breeze and ecverything started syncing. Now as ...
Marc_V
Jan 16, 2018NETGEAR Employee Retired
Hi AFAYK
Welcome to the Community!
Are you getting any message? Have you checked the logs?
Can you try syncing one way and see if data will be pushed to Dropbox fine. Recommendation is that Dropbox cap should be equal or higher than the NAS cap.
Regards
AFAYK
Jan 16, 2018Aspirant
Thank you Marc.
There doesn't seem to be any messages.
There is no cap on the NAS itself, and the Dropbox ap installed only has three settings.
The cap for the dropbox account is around 5tb and we are at 3tb.
Attached are screen shots of image uploaded (uploadedchicken) uploaded through the web interface, and then a screen shot showing the local files on the NAS without the uploaded file appearing. I do not know how much time should be allowed to pass.
So, syncing is not happening in either direction bewtween the NAS and the dropbox account.
I have set up this same NAS twice to work with Ignight and havent had issues, and I am familiar with them, fyi.
Thanks again.
- AFAYKJan 16, 2018Aspirant
The screenshot was on the local end. here is the one on the Dropbox end:
- Marc_VJan 17, 2018NETGEAR Employee Retired
Have you tried with one way sync? did it sync the data to the Dropbox?
- AFAYKJan 17, 2018Aspirant
Actually, I made a dns addition to the network card setting on the NAS, then restarted it. I am seeing a lot of activity now, and the NAS is downloading a lot of stuff. I created a folder in the cloud via the dropbox web interface and it created tht same folder on the NAS.
The direction is still set to bidirectional. Do you know what methodology it uses for the exchange of files? Meaning, does it perform all the downloads first, then do the uploads, or is it a function of date/timestamp, or some secret formola. I'm just wondering if once it catches up on all the downloads if it will then go through all the uploads to be in sync. Hopefully that will be the case.
If that is indeed what happens then I should hopefully be good to go, thopugh I would have a solid answer as to why. Thanks!
(screen shot shows that there is a lot of download activity by the device now)
