AFAYK
Jan 15, 2018Aspirant
ReadyNAS not syncing anymore with dropbox. Was originally
This is regarding the ReadyNAS 426. The form wouldn't let me seleect that. I set it up to sunc both ways with Dropbox. Initially the setup was a breeze and ecverything started syncing. Now as ...
AFAYK
Jan 16, 2018Aspirant
The screenshot was on the local end. here is the one on the Dropbox end:
Marc_V
Jan 17, 2018NETGEAR Employee Retired
Have you tried with one way sync? did it sync the data to the Dropbox?
- AFAYKJan 17, 2018Aspirant
Actually, I made a dns addition to the network card setting on the NAS, then restarted it. I am seeing a lot of activity now, and the NAS is downloading a lot of stuff. I created a folder in the cloud via the dropbox web interface and it created tht same folder on the NAS.
The direction is still set to bidirectional. Do you know what methodology it uses for the exchange of files? Meaning, does it perform all the downloads first, then do the uploads, or is it a function of date/timestamp, or some secret formola. I'm just wondering if once it catches up on all the downloads if it will then go through all the uploads to be in sync. Hopefully that will be the case.
If that is indeed what happens then I should hopefully be good to go, thopugh I would have a solid answer as to why. Thanks!
(screen shot shows that there is a lot of download activity by the device now)
- Marc_VJan 17, 2018NETGEAR Employee Retired
All right, it seems that DNS is the answer. You can click on accepted solution button once we are sure that everything is working.
If I am correct it dowloads all data to dropbox first then any changes made on both end will be updated.
- Marc_VJan 21, 2018NETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- AFAYKJan 23, 2018Aspirant
Hi. I wanted to give it a couple days to catch up in case that's what was the issue. I just checked back again and although it is definitely syncing a lot, Dropbox it hasn't created the empty directory or the two test images i created locally a few days ago.
It really has to work all or nothing or we can't depend on it. Ao I don't know why those files have yet to move. :(
