vasyam
Sep 26, 2020Tutor
ReadyNAS Pioneer Pro OS6 volume missing after hard reset
Hello, I am running OS6.10.3 on my legacy RNDP6000-100 Pioneer Pro. It works generally fine but freezes someties and the only way to unfreeze it was to perform a hard reset which also worked general...
- Sep 28, 2020
Got it, thank you
Sep 26, 2020Guru - Experienced User
There must have been pending disk writes when you did the hard reset - resulting in an out-of-sync RAID array.
The puzzle here is to understand why the system hangs. One possibility is that it has insufficient memory. Are you using the stock 1 GB, or have you upgraded the RAM?
vasyam
Sep 26, 2020Tutor
I have added a 4Gb stick and upgraded the processor
