vasyam
Sep 26, 2020Tutor
ReadyNAS Pioneer Pro OS6 volume missing after hard reset
Hello, I am running OS6.10.3 on my legacy RNDP6000-100 Pioneer Pro. It works generally fine but freezes someties and the only way to unfreeze it was to perform a hard reset which also worked general...
- Sep 28, 2020
Got it, thank you
vasyam
Sep 26, 2020Tutor
I have added a 4Gb stick and upgraded the processor
Sep 26, 2020Guru - Experienced User
So 5 GB total? Whether 4 or 5 GB, it should certainly have enough RAM.
Have you tried accessing the NAS with ssh when it appears to hang?
- vasyamSep 26, 2020Tutor
I did not as I am just a user and need to educate myself for this kind of steps when absolutely needed)
And yes, 5Gb total RAM
- StephenBSep 26, 2020Guru - Experienced User
vasyam wrote:
I did not
Then I suggest downloading the log zip file, and looking for any clues about the hang in there.
Are you running apps? If so, which ones are installed.
I have downloaded the log files, but am not sure where to look. I do not believe I am running any apps besides Transmission
