sayerns
Oct 14, 2016Aspirant
ReadyNAS surveillance on os6.6
Can someone from ReadyNas tell me when Surveillance will be updated to work with OS6.6?
- Oct 18, 2016
Hello sayerns,
What I have just learned is that engineering is doing some evaluation on the update that hopefully is out this month. No promises but engineering is doing their best to release an update the soonest possible time.
We again apologize for the inconvenience.
Oct 18, 2016Guru - Experienced User
sayerns wrote:
So do i have to just wait here for an expert to contribute or should i be posting elsewhere?
You posted in the right place, hopefully someone from netgear will reply soon.
JennC
Oct 18, 2016NETGEAR Employee Retired
Hello sayerns,
- sayernsOct 28, 2016Aspirant
Thank you for the update. Readynas surveillance working fine on OS 6.6 now.
- JennCOct 28, 2016NETGEAR Employee Retired
Hello sayerns,
I am glad it now works and appreciate your feedback.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Nov 24, 2016Retired_Member
