Aurshur
Jul 08, 2014Aspirant
Readynas Ultra 6, Make command and other problems
Hi, I am utterly hopeless with linux, I have been trying to a program called Ps3netsrv to enable me to mount ps3, blu ray and dvd isos over my network, however I'm utterly at a loss how to proceed....
mdgm-ntgr
Jul 08, 2014NETGEAR Employee Retired
No need to apologise. I had to learn about this too some years back.
See the # at the start of the last line.
You need to remove that e.g. using vi
Lookup the MAN page for vi to see how to use it.
You should find it very useful.
After you have uncommented the line and saved your changes you can try again
# vi /etc/apt/sources.list
# apt-get update && apt-get install build-essential
