SuperFlyBoy1
May 30, 2013Aspirant
ReadyNAS Vault using rsync??
I was just checking one of the shares (our main one) on the NV+ we have in the office, and apparently there was a rsync enabled to 64.64.131.102, which I do not think was set by me. (The only admin in...
May 30, 2013Guru - Experienced User
If you never enabled ssh, then the root password is the same as the admin password - and you changed them both.
If someone could see the dataflow on the path to the destination, then they could theoretically use rsync (spoofing the IP address). Though I think it is more likely that rsync terminated on the IIC Internet server.
Are you certain it was on the NAS, and not someone else in the company using rsync for something else?
