RAP66
Oct 11, 2017Aspirant
ReadyNAS314 and multiple DropBox accounts
Hello I finally picked up a NAS system for some of my files. I was able to add a DropBox folder to my ReadyNAS314 and would like to add a second DropBox folder connected to a different account. H...
- Oct 18, 2017If you need a second Dropbox account synced to the NAS now you could take a look at the Dropbox for R6 app at rnxtras.com
Marty_M
Oct 18, 2017NETGEAR Employee Retired
Hello RAP66,
It does appear that you would like to add another dropbox account to the cloud dropbox feature of the readynas device. Unfornately you can only use one account to activate the dropbox feature of the NAS and there is no option adding new account. The feature can be raised to the Readynas Idea exchange board, adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
Welcome to the community!
Marty_M
NETGEAR Community Team
- mdgm-ntgrOct 18, 2017NETGEAR Employee RetiredIf you need a second Dropbox account synced to the NAS now you could take a look at the Dropbox for R6 app at rnxtras.com
- RAP66Oct 18, 2017Aspirant
Thank you both for the response..
I will check out the app.
-Rich
- RAP66Oct 22, 2017Aspirant
I got that software mentioned but when I try to use it I get this warning <img attached>
Can someone confirm if this is a false positive??
Thanks
-Rich
- mdgm-ntgrOct 23, 2017NETGEAR Employee Retired
The NAS uses a self-signed certificate. You can ignore the warning when logging into the local admin page.
This is fine for your NAS but obviously not for online banking or an online store.
- Apr 16, 2020Retired_Member
