ANDYMIH
Aug 22, 2018Aspirant
Resilio Sync lost permissions to write after update
Hello! I have a Readynas Ultra 6 with a firmware 6.9.3 installed. And i have Resilio Sync installed. That apped worked perfectly until last update to version 2.5.12. After the update all folder...
Retired_Member
Aug 23, 2018Hi ANDYMIH, you might have quotas enabled and the area resilio is allowed to write to is "full". So, try to continue with quotas disabled, if possible. Good luck with fixing and kind regards.
- StephenBAug 23, 2018Guru - Experienced User
Start by confirming that your volume hasn't become read-only. The simplest way to do that is to copy a file from a PC.
Once that is done, I suggest resetting the file permissions for the share. This is done by clicking the share settings wheel, then "settings". Click on the file access tab, and you will see a reset control on the lower left.
>>> The users andy and admin belong to users group.
admin should be in the admin group.
- ANDYMIHAug 23, 2018Aspirant
Hi!
No, its not quotas, because Sync can write in its own folder, and i can copy files to my home folder from my pc for example.
Thatnks for the try !!!
Hi, StephenB!
The volume is writable.
I guess i cant reset permissions like you say, cause the folder is in my HOME folder (thats created when you create a user in readynas), not share.Admin belongs to both groups.
I experimented today and chown'ed my home folder owner to admin and Sync was able to write.
Finally, i decided to move the backups in Resilio's default folder and not waste our time for that thing.
Thank you and Retired_Member !
ANDYMIH wrote:Finally, i decided to move the backups in Resilio's default folder and not waste our time for that thing.
That is better. There is some special ACL applied to the home folders, and it's best not to mess with that. You can explore it with getfacl if you are interested.
