dtarin
Aug 22, 2023Luminary
Resilio sync permissions
I am playing around with Resilio sync and noticed that files created by a client on a folder is created in readynas with user root and group root permissions. Anyone here know how to adjust at le...
NiveditaP3
Aug 31, 2023NETGEAR Expert
Hello dtarin
And welcome to the NETGEAR Community! đ
Please find the steps to set permission:
Set Network Access Rights to Shares for Common Protocols
In addition to a way to set access rights for all protocols including advanced settings,
the admin page provides a simplified way to set rights for the most commonly used
networking protocols and settings.
The mostly commonly used networking protocols are SMB, AFP, FTP, and HTTP. Use
this procedure as a simplified way to setting access rights for these protocols.
To set the network access rights for a shared folder:
1. Log in to the admin page.
2. Select Shares > Shares.
A list of shares and LUNs on each volume displays.
3. Hover over the shared folder that you want to configure.
4. Click the plus icon for the folder.
5. Adjust the settings as needed.
âą To adjust existing permissions for a user or group, use the Access menu for that
user and select the new access level. You can click on the arrow icon by a user
or group name to expand the list, if there are multiple protocols set for the user
or group.
âą To remove permissions for a user or group, click the X icon for that user or group.
âą To add additional permissions, use the menus at the bottom of the window to
specify the user, the protocol, and the access level, and click the Append button.
6. Click the Close button.
Your changes are saved and the window closes.
Have a lovely day,
Nivedita Pa
Netgear Team
