grahamu59
Jan 11, 2017Tutor
RN102 6.6.1 and Contacts and Calendar server
Since upgrading to 6.6.1 the contacts and calender server is unreachable both remotely and the local admin page from the NAS GUI. Did I miss this on the app incompatibility list or should it still be...
grahamu59
Jan 13, 2017Tutor
This was tried on 3 browsers, that was not the issue, my clients would not have failed syncs in the logs if it were. However this seems to have been a post upgrade glitch only. The upgrade itself went fine burt post reboot the cal&contacts server did not start. Subsequent to this however it has started as epxected with each overnight scheduled reboot. Not sure why it failed post upgrade but all is well now thanks.
JennC
Jan 13, 2017NETGEAR Employee Retired
Hello grahamu59,
Did you try turning it OFF then ON and see if you get the same problem? Or remove the app then reinstall?
- grahamu59Jan 13, 2017Tutor
It can't be turned of in the GUI. I have not needed to try reinstalling but that would have been my next step.
- JennCJan 16, 2017NETGEAR Employee Retired
Hello grahamu59,
If you get the same results, you might need to contact support.
- FramerVJan 21, 2017NETGEAR Employee Retired
Hi grahamu59,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
