DJL-Consulting
May 18, 2016Tutor
RN104 recent Update to 6.5.0 Deluge Download Folder Permission Problems
Hi All, Sorry to trouble you. But I am having some real problems with an App downloaded and installed from ReadyNas Xtras. The App, Deluge 1.3.12 has been fine after installing on my Netgeat RN1...
JennC
May 18, 2016NETGEAR Employee Retired
Hello DJL-Consulting,
The app is not listed at ReadyNAS apps that were submitted to Netgear. Also, since that is an app, only the developer can help you. They might need to adjust something on the app since the 6.5.0 is a major FW release.
Welcome to the community!
May 18, 2016Guru - Experienced User
This came from WhoCares_, correct? Perhaps PM him here if you can't reach him at rnxtras.com
- DJL-ConsultingMay 19, 2016TutorYeah it was, I have emailed him twice now - but to no avail, I am literally a step away from doing it myself just a few pointers with CLI Code that is all. I will try and PM him now and see if he can help, as it is very frustrating.... Thanks all. :-)
- JennCMay 19, 2016NETGEAR Employee Retired
Do you still have a way to grab the app and reinstall it?
There are some apps that get problem with updating after upgrade to 6.5.0, I am not sure but may be it has something to do with the app you are trying use again.
JennC wrote:Hello DJL-Consulting,
Yes JennC,
That was my first port of call, unfortunately to no avail. I shall have a proper look in due course and thanks for the information....
Best regards,
DJL-Consulting
