DJL-Consulting
May 18, 2016Tutor
RN104 recent Update to 6.5.0 Deluge Download Folder Permission Problems
Hi All, Sorry to trouble you. But I am having some real problems with an App downloaded and installed from ReadyNas Xtras. The App, Deluge 1.3.12 has been fine after installing on my Netgeat RN1...
May 18, 2016Guru - Experienced User
This came from WhoCares_, correct? Perhaps PM him here if you can't reach him at rnxtras.com
DJL-Consulting
May 19, 2016Tutor
Yeah it was, I have emailed him twice now - but to no avail, I am literally a step away from doing it myself just a few pointers with CLI Code that is all. I will try and PM him now and see if he can help, as it is very frustrating.... Thanks all. :-)
- JennCMay 19, 2016NETGEAR Employee Retired
Hello DJL-Consulting,
Do you still have a way to grab the app and reinstall it?
There are some apps that get problem with updating after upgrade to 6.5.0, I am not sure but may be it has something to do with the app you are trying use again.
- DJL-ConsultingMay 19, 2016Tutor
JennC wrote:Hello DJL-Consulting,
Yes JennC,
That was my first port of call, unfortunately to no avail. I shall have a proper look in due course and thanks for the information....
Best regards,
DJL-Consulting
