DJL-Consulting
May 18, 2016Tutor
RN104 recent Update to 6.5.0 Deluge Download Folder Permission Problems
Hi All, Sorry to trouble you. But I am having some real problems with an App downloaded and installed from ReadyNas Xtras. The App, Deluge 1.3.12 has been fine after installing on my Netgeat RN1...
jaybepr
May 19, 2016Tutor
My friend we have tried everything, There is no errors messages, it just won't acces SMB. Everything else works even the cloud, DLNA, FTP, admin page, RaidAR finds them no problem. Just to see I took out my old Readynas NV and install a 500GB drive, it connected like nothing and it works like the other ones used to work before the Firmware upgrade. Netgear customer support was connected to my computer for over 4 hours and couldn't find the problem. I tried five different computers on the same network with the same problem, if I go to the network and search I can see both NAS but when I try to go inside I can't, just like if they were disconnected from the network, but remember I can see them when I go to search on Network. It's got to be something related with the Firmware.
- DJL-ConsultingMay 19, 2016Tutor
jaybepr wrote:
My friend we have tried everything, There is no errors messages, it just won't acces SMB. Everything else works even the cloud, DLNA, FTP, admin page, RaidAR finds them no problem. Just to see I took out my old Readynas NV and install a 500GB drive, it connected like nothing and it works like the other ones used to work before the Firmware upgrade. Netgear customer support was connected to my computer for over 4 hours and couldn't find the problem. I tried five different computers on the same network with the same problem, if I go to the network and search I can see both NAS but when I try to go inside I can't, just like if they were disconnected from the network, but remember I can see them when I go to search on Network. It's got to be something related with the Firmware.Hi Jay (hope it is okay to call you that?),
It sounds like a real nightmare, I shall look at what I can do (from research and if need be help from here) and see what my ReadyNas RN104 is upto tomorrow (I am a Network/IT Consultant) and see if there are any pointers or help I can give or advise you further with.
I hope that is okay.
DJL-Consulting (Dan) :smileyhappy:
