DJL-Consulting
May 18, 2016Tutor
RN104 recent Update to 6.5.0 Deluge Download Folder Permission Problems
Hi All, Sorry to trouble you. But I am having some real problems with an App downloaded and installed from ReadyNas Xtras. The App, Deluge 1.3.12 has been fine after installing on my Netgeat RN1...
jaybepr
May 22, 2016Tutor
OK my friend this is what I just find out , I don't know if somebody else wants to try it and let us know but this is my results. I have 2 NAS a 104 and a 314, I decided to backup my 104 to my pc and did a factory default reset And believe it or not after that everything is back to normal on the 104, the 314 still have the same problem. On the 104 I clean the disks and start all over again. If you want to try this do it on your own risk, for me it worked. Now I am going to back up the 314 to the 104 and try the same thing on it. Good luck and let us know your results.
Shtoffen
May 22, 2016Aspirant
There is small problem, with backing up 2TB of data...
