pk19
Jul 29, 2020Aspirant
RN214 Disk space
Probably a really dumb question but I have just got a RN214 and have installed 3 x 4TB (2 Seagate / 1 WD) and 1x3TB drive (Seagate) = 15TB. I've gone for Raid 0 as I needd maximum space. The RN2...
pk19
Cheers, yes the JBOD option would be perfect as that works well... just this model does not seem to have a JBOD option, just RAID.
I thought it was probably a disk size issue so thanks for confirming that.
I will keep tweaking.
Thanks.
Sandshark
Jul 29, 2020Sensei
It definately has the JBOD option. You just have to create them one at a time. If you select multiple drives, you will not be offered that option.
