makhtoriq
Jan 28, 2021Aspirant
RN314 dispaly retry startup
Hello can anyone help My problem is on the NAS RN31400 device the problem is when it finishes booting, it says "Retry Startup" on the NAS display is there a solution? I have tried upgrading the ...
mdgm
Jan 28, 2021Virtuoso
Do you have a backup?
USB Boot Recovery is not the solution to this problem. USB Boot Recovery is not a "magic" fix for any and every problem.
It's only for where the problem is with the firmware on the internal flash. The error "Retry Startup" doesn't indicate a problem with the firmware on the internal flash.
From memory the error "Retry Startup" suggests that readynasd, the management service failed to start.
Try downloading the logs using RAIDar. If you can download the logs look at readynasd.log and the entries related to readynasd in systemd-journal.log. These log entries should give an indication as to what's wrong.
As for doing USB Boot Recovery not all USB keys are compatible. If the key isn't formatted correctly or the necessary files are not put on it also won't work.
makhtoriq
I don't have backups on this NAS
