makhtoriq
Jan 28, 2021Aspirant
RN314 dispaly retry startup
Hello can anyone help My problem is on the NAS RN31400 device the problem is when it finishes booting, it says "Retry Startup" on the NAS display is there a solution? I have tried upgrading the ...
Sandshark
Jan 28, 2021Sensei
An OS re-install from the boot menu may be a fix for you, but it's best to try and find the cause first. In addition to the readynasd.log, look in btrfs.log and make sure the OS (root) partition isn't full or nearly so. If it is full, an OS re-install can do more damage than good (and so could have a USB recovery if you had succeeded). You should have an entry like this at the top, and the space in use should not be approaching 4GiB:
Label: '7fc780f2:root' uuid: 7e15fc17-8765-457e-8a81-156ddea84fa0 Total devices 1 FS bytes used 805.62MiB devid 1 size 4.00GiB used 1.64GiB path /dev/md0
You may have to be quick with RAIDar to get the logs.
makhtoriq
I can't enter the boot menu
My NAS is undetectable in RAIDar and I can't access the files on my NAS
- mdgmJan 28, 2021Virtuoso
Looking at previous posts USB Boot Recovery has helped if there was a firmware specific issue such as what was encountered by some users on 6.7.3.
You could try different USB keys. Also try running the Windows utility to create a USB Boot Recovery Key as an Administrator.
