UKGeoffnew1's avatar
UKGeoffnew1
RN4220S NASOS 6.8.0/6.8.1 - Applications no longer working
This week my RN4220S NASOS upgraded to 6.8.0 and then 6.8.1 but all the applications that were loaded and working perfectly for many months have stop working and initialising.   I can see that this...
  • Marty_M's avatar
    Marty_M
    Oct 03, 2017
    Hello UKGeoffnew1,
    Thank you for the update and sharing resolution/work around,  it does appear that the NAS is working fine as it should. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. You may also choose your reply as solution for the thread.
    The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    Marty_M
    NETGEAR Community Team
ProSupport for Business
