WhoCares_
Dec 12, 2011Mentor
SABnzbd 0.7.20 (+ unRAR 5.1.6)
SABnzbd 0.7.20
- Description:
SABnzbd is an Open Source Binary Newsreader written in Python. It's incredibly easy to use, and works practically everywhere. SABnzbd makes Usenet as simple and streamlined as possible by automating everything we can. All you have to do is add an .nzb. SABnzbd takes over from there, where it will be automatically downloaded, verified, repaired, extracted and filed away with zero human interaction.
- Requirements: RAIDiator 5.3.2 or newer
For this add-on to work,the Python2.7 add-on has to be installed on your ReadyNAS.
- Platform: ARM
- Current Version: SABnzbd 0.7.20
- Changes in this release:
- Update to new release of SABnzbd
- Update to unRAR version 5.1.6
- Includes 'Kickstrap' theme for faster page load and mobile devices
- Details/Installation:
- After installation of the add-on, SABnzbd's web interface can be accessed by typing http://<ip of your NAS>:2708/ in your browser's address field. You will be presented with the setup wizard:
- After choosing your language and clicking on "Start Wizard" you'll be taken to the theme selection. I prefer the "Plush" theme but the choice is yours:
- If you want to protect access to the SABnzbd web interface, enter the credentials on the next screen. Important: If you opt to use HTTPS here, the port on which the interface is accessible will change to :9090 once the wizard is finished!.
- The next step is important. Enter the credentials to access your usenet providers news service. If you fail to enter proper credentials, the wizard will continue but you'll be redirected to the wizard setup on each access to the web interface until the credentials work! (so: don't use the ones from the screenshot, please. They won't work.)
- If you have an account with one of the two listed nzb search engines, you can enter that on the next screen:
- Once the wizard is finished SABnzbd will restart itself. It will also present you with a screen where it tells you on what URL to find the web interface in case any of the port settings have changed:
- Oce you made it to SABnzbd's real web interface, you may wish to change the location of downloaded files.
- As you can see, SABnzbd will place files into the "download/complete" directory. Since this is already symlinked to your "Media" share, you may leave that as is. If, however, you want to change the location, make sure to use the "/c/<name of the share>/<folder>/.." syntax. Also check that the destination directory is accessible for the "admin" user because that's the account SABnzbd is running under. If you want to make downloaded files accessible by every user on the NAS don't forget to set the "Permissions for completed downloads" to "777" (without the quotes).
- WhoCares_Mentor
- WhoCares_Mentor
- WhoCares_Mentor
- willy134ukAspirant
Could we get the latest version packaged please
Nevermind im lookng at BETA not final releases
final has now released can we get it packaged please :)
